隔离电流传感器解决了电路的安全问题
在许多与电源有关的应用中,必须知道导体中电流的多少。诀窍是了解许多电流可以测量的方式,并根据关键要求,如安全,功率,成本,形状因子和电路可访问性作出正确的选择。
需要电流感应的情况包括电机控制反馈,电源操作,或大功率充电太阳能电池阵列。当电流与电压低至中等,如在1和10 V,测量电流是相当简单:只需插入电流电阻(通常在毫欧的范围)的电流进行评估的路径,然后测量电阻两端的电压。虽然有问题的大小的电阻器,以尽量减少不希望的电压降,同时提供了足够大的电位差(电压)横跨电阻的精确测量,这种关注可以解决一些基本的计算和一个合适的放大器横跨电阻。
If the resistor is grounded at one end (called low-side sensing), the measuring circuit is very straightforward. However, if the resistor is not grounded (high-side sensing), a differential amplifier is needed to measure that voltage across the resistor – without any reference to ground. In many applications, the high-side sense circuit will also have to be galvanically isolated for safety or performance, usually using an optocoupler or transformer-based isolator.
Isolation of sensing circuitry is needed for technical and regulatory reasons in the many situations where high voltages and currents are common, such as line-operated industrial and commercial motors, electric/hybrid electric vehicles (EV/HEV), solar arrays, home energy metering, and many other less-visible applications. It also adds a major safety barrier, often mandatory, in case there is a component failure or human failing which might put higher or primary-side voltages on the secondary-side circuit. It adds to cost and complexity, of course, but allows the sense resistor to be several thousand volts above ground.
