以太网电源解决方案的智能大厦的应用
智能建筑给业主和居住者带来了许多好处。通过使用传感器收集环境和占用数据,供暖和空调系统可以优化,以保持驾乘舒适,不浪费能源。照明系统可以响应入住率和白天条件的时间,使室内照明节能以及。外部照明系统,智能控制,提高安全性和安全性。智能建筑应急系统可以识别最快和最安全的出口路径的居民或入境应急响应
如果电源线不需要与智能楼宇的传感和控制子系统,部署灵活性可以显着增强。使用以太网的电源(PoE)可以增加子系统部署选项,同时保持一个“硬化”的通信能力,更强大,更安全,比无线实现。本文将提供一个POE系统的关键元素,并说明它们是如何实现的一个例子设计。
The Basics
PoE is a power delivery and data communications standard that can provide a convenient source of power to remote sensors, aggregators, wireless gateways, security cameras, and controllers within a smart connected building. Power is delivered safely and can source up to 12.95 W (IEEE 802.3af) and up to 25.5 W for the emerging IEEE 802.3at standard.
Figure 1 below shows a typical PoE system with the power-sourcing equipment (PSE) on the left and the powered device (PD) on the right. In this example the power source is an Ethernet Switch and the powered device is an office phone. The two devices are connected via the Ethernet twisted-pair cable using two wires for data and the two spare pairs for the delivered 48 V power source. Power is managed by a special PSE controller, on the power sourcing side and a power delivery interface and DC/DC converter on the delivery side.
