开发工具包提供低风险进入太阳能收集
太阳能收集已经在高度复杂的设备中找到了支持,这些设备集成了一套需要最大限度地将太阳能转换为电能的功能。工程师可以快速获得这些设备的–更深层次的理解和获取能量的原理,利用低成本的评估套件从能量收集IC制造商包括模拟设备,一般–德克萨斯仪器,和意法半导体。
虽然太阳能电池与光伏电池的概念是直接的,一个高效的能量收集系统的实施依赖于一个坚实的升值无数的细节。在这些细节,适当的太阳能光伏电池板的负载是必不可少的,因为光伏面板的最大输出发生在光伏电池板的功率曲线的一个精确点上。这个最大功率点(MPP)可以改变整个家庭的各种因素包括光照明面板强度相关曲线,环境温度,在面板的光伏电池的年龄和健康状况,与面板的电压由面板上的荷载确定(图1)。因此,最有效的能量收集设计采用最大功率点跟踪(MPPT)的方法,动态调整负载的光伏电池,以维持其在MPP的操作。
Figure 1: Among various factors affecting solar-energy conversion, the photovoltaic cell or panel voltage determined by the load can dramatically shift the maximum power point. (Courtesy of Texas Instruments)
MPPT optimization methods can be complex – in fact, MPPT algorithms continue to be the subject of research in academia and industry. Nevertheless, specialized energy-harvesting devices such as the Analog Devices ADP5090, STMicroelectronics SPV1050, and Texas Instruments bq25505 offer integrated MPPT capabilities that can meet the needs of many energy-harvesting applications. Although these MPPT-capable ICs simplify implementation of efficient energy-harvesting systems, they themselves are complex devices that require careful attention to details associated with their configuration and operation.
