物联网和移动设备的天线选项
消耗积分:0 | 格式:rar | 大小:0.06 MB | 2017-05-23
分享资料个
  物联网和移动设备的天线选项
  天线(被称为“天线”在某些国家)是第一个组成部分,在接收器射频信号链和最后一个在发射链。虽然在概念上是一个简单的能量转换器之间的电压/电流在电路和相应的电磁场(EM)领域辐射到或从空间,有许多执行问题与此基本的无源元件。
  天线基本理论覆盖了许多书籍,文章和网站(三应用笔记LINX技术是特别有用的1,2,3)。今天的天线用户和设计师也使用强大的和相当准确的软件工具,模型的天线和相关的电磁场。这些允许详细的模拟天线的“自由场”的特点,以及它的性能在最终产品和安装,天线本质上与他们周围的环境互动。这些工具是特别重要的PC板的设计,其中的天线和其余的电路是在接近。
  物联网和移动设备的天线选项
  Further, the growth of small, low-power wireless devices, such as for the Internet of Things (IoT) and handheld/portable devices, has placed new performance mandates on operating frequency, bandwidth, size, physical design, and radiation pattern/directivity/gain of this “unglamorous” component. Designers can choose among many fundamental antenna types, including external longwire, short whip, PC-board fabrication, ceramic chip, and proprietary (custom-designed) styles. The whip, PC-board, and ceramic-chip antennas are the most practical choices for IoT and mobile devices operating in the GHz region.
  The whip antenna is an external discrete component, usually up to about 2 to 4 inches (5 to 10 cm) long at these frequencies. It offers well-defined, self-contained performance specifications which are largely independent of the transmitter/receiver itself. The whip can be attached directly to the PC board via a board-mounted connector, or located nearby and connected via a coax cable. While both the coax cable and PC-board connector add cost in addition to the antenna itself, this arrangement allows flexibility in PC-board design as well as end-product packaging and installation.
评论(0)
发评论
下载排行榜
