OZ9RR,pdf datasheet
消耗积分:10 | 格式:rar | 大小:333 | 2009-11-03
贾熹
分享资料个
OZ9RR MULTIPLE-CCFL INVERTER TRANSFORMER SELECTION/ DESIGN GUIDE
1. Choose a transformer from a catalog based on the following parameters of the application:
a) Output power
b) Output voltage, including open voltage
c) Size
d) Operating temperature range
2. For a multiple-CCFL design, there are 3 options for implementation. Recommended ranges for secondary main inductance and leakage inductance of each transformer are indicated for each option suitable for most applications with operating frequency range of 40-60kHz and CCFL power rating of 3-5W. Secondary leakage inductance can be adjusted through gapping of the core. Theoretical relationships between the
transformer parameters and the inverter output stage components are discussed in the supplemental information at the end of this document.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
