变压器设计应考虑什么安全标准
离线反激式脉宽调制(PWM)与集成MOSFET是电源系统设计的一个组成部分。半导体器件将不符合设计要求,除非所有其他部分完成系统也做他们的工作。变压器是一个重要的组成部分,通常被视为别人的问题。这可能是真正的公司,可以负担得起一个专门的磁专家,但这个位置通常不存在,工作只是另一个工程师的责任的一部分。设计合适的变压器需要考虑这六个方面:
安全标准
设计要求
集成电路的选择
如何使它的可制造性,并允许制造商的灵活性
如何验证他们是否有好的设计
确保良好的成本与性能平衡
本文将总结六大安全标准和途径,以帮助电源和变压器设计。
When designing an offline flyback power supply, integrating the IC with the other components can be overwhelming. Integrating the transformer properly is more than finding the turns-ratio to match with application input and output(s)。 Many customers might think, “I thought a Flyback transformer is just transferring energy across a safety isolation barrier. I guess there is more to understand.” Not knowing the safety standards will usually mean more iterations than necessary when working with a transformer manufacturer. Not knowing the safety standards can lead to unwanted surprises of non-conformance at the qualifying labs and sending a product back to design phase rather than qualification before mass production.
