Using the Stellaris Microcontr
消耗积分:3 | 格式:rar | 大小:223 | 2009-11-07
分享资料个
Luminary Micro Stellaris™ microcontrollers that are equipped with an analog-to-digital converter(ADC), use an innovative sequence-based sampling architecture designed to be extremely flexible,yet easy to use. This application note describes the sampling architecture of the ADC. Sinceprogrammers can configure Stellaris microcontrollers either through the powerful StellarisFamilyDriver Library or through direct writes to the device's control registers, this application note describesboth methods. The information presented in this document is intended to complement the ADCchapter of the device datasheet, and assumes the reader has a basic understanding of howADCsfunction.
评论(0)
发评论
下载排行榜
