Replacing the Candle in the Candelabra
两种紧凑、高效的灯泡更换设计思路
作为标准白炽灯的插件,LED灯现在在零售商店中很显眼。拟合的保护和恒流驱动电路所需的LED灯泡在标准尺寸的脖子一挤,尤其是使用T8管或紧凑型灯,爱迪生螺杆设计。在这样的应用中,驱动电子学的空间非常小,限制了可以使用的组件的大小和数量。空间的缺乏也加剧了热管理的问题。更糟糕的是,LED负载被定位,因此它与电源紧密接触。为了避免过热和由此造成的故障,LED驱动器必须以尽可能高的效率运行。
严格的规定
以及提供一个稳定的恒流输出,LED驱动器(电源),必须符合日益严格的法规涵盖了功率因数和谐波的电流由电源失真。1多个LED驱动器解决方案使用一个两阶段的方法具有PFC阶段的恒流驱动,往往一个反激变换器。升压PFC级通常实现最大效率为95%,恒流驱动器约为90%,整体效率为85%。
This approach requires an inductor, two power switches, and two controllers, – a lot of components to fit into a tiny lamp housing. The PFC stage and the flyback converters are both performing a similar function of switching current flow on and off, or shaping the input and output current, respectively. If the two switching activities could be combined into a single stage, fewer components would be required, and much higher efficiency could be achieved with only one driver circuit and one switching stage.
