无刷直流电机控制简介
无刷直流电机(BLDC)如汽车行业越来越受欢迎(特别是电动汽车(EV))、暖通空调、白色家电和工业因为它不用于传统电机的机械换向器,取而代之的是一种电子装置,提高了机组的可靠性和耐久性。
无刷直流电动机的另一个优点是,它可以比刷子类型更小,更轻,具有相同的功率输出,使前者适合于空间紧的应用场合。
缺点是无刷直流电机确实需要电子管理才能运行。例如,一个微控制器-使用传感器的输入来指示转子的位置-需要在适当的时候给定子线圈充电。精确的时间允许精确的速度和扭矩控制,以及确保电机运行在最高效率。
本文阐述了无刷直流电动机运行的基本原理,描述了三相机组运行的典型控制电路。文章还考虑了一些集成模块,设计者可以选择简化电路设计,这些电路是专门为BLDC电机控制而设计的。
The advantages of brushless operation
The brushes of a conventional motor transmit power to the rotor windings which, when energized, turn in a fixed magnetic field. Friction between the stationary brushes and a rotating metal contact on the spinning rotor causes wear. In addition, power can be lost due to poor brush to metal contact and arcing.
Because a BLDC motor dispenses with the brushes – instead employing an “electronic commutator” – the motor’s reliability and efficiency is improved by eliminating this source of wear and power loss. In addition, BLDC motors boast a number of other advantages over brush DC motors and induction motors, including better speed versus torque characteristics; faster dynamic response; noiseless operation; and higher speed ranges.1
