工业自动化数据采集的无线结构
本文讨论了用于无线分发的数据捕获的不同选项,以支持工业自动化应用程序。它着眼于数据捕获的不同层次的集成,以及用于连接传感器和其他设备的不同无线技术的接口。它涵盖了芯片mrf49xa收发器在ISM频带低于900赫兹和Silicon Labs em351 2.4 GHz的应用。
片上系统(SOC)设备在工业自动化无线数据采集设计中越来越流行。收发信机需要一个微控制器来处理协议栈和传入的数据打包。将控制器与无线电前端结合起来,减少了设计的足迹、成本和复杂性。频带和协议的选择取决于数据带宽的要求,而这又取决于所使用的传感器结构和数据采集系统。
然而,对于较低的数据速率、低成本的较低频段的应用,仍然有一个单独的收发器,可以很容易地集成到低成本控制器,与数据转换器和传感器子系统的要求相匹配。
Wireless systems are used to link sensors around the factory floor to a central monitoring point. These wireless sensor networks (WSN) provide vital data, from the status of a process to the health of a piece of machinery. This helps optimize the performance of the industrial process and flag problems with equipment to allow for replacement before it fails, avoiding costly down time.
Integrated system-on-chip devices such as the Silicon Labs EM351 use the I²C interface, which is a common output from an analog-to-digital converter (ADC)。 This, along with the SPI interface, can dramatically simplify the design of the node, providing a simple two or four wire interface to the data converter. The choice of converter will be determined by the output protocol to ensure they are well matched in performance – from a lower data rate 868 MHz ISM band with an 8-bit controller to a 2.4 GHz ZigBee node with a 32-bit processor.
