提高风力机运行效率的节距控制
风力发电已成为越来越受欢迎的公用事业规模的应用,在这个地区的自然和可再生资源是现成的。像大多数天气和气候的因素一样,风速是多变的,而且从电力工程师的观点来看是相当不可预测的。因此,风力涡轮机的设计不仅要承受全方位的自然力,而且要在尽可能广泛的输入范围内有效地获得能量。下面的公式告诉你风中有多少能量(而不是你能提取多少):
有效风功率(瓦)= 1 / 2 *大* * V³
哪里:
空气密度= 1.23(海平面1立方米,空气重1.23公斤)
平方米的风力涡轮机扫掠面积。对于一个叶片直径为3米的风力涡轮机-约10英尺-扫面积将约80平方英尺。
速度(风速)。注意V立方。这意味着如果你加倍风速你有8倍的能量。一种风力发电机,在时速10英里的风力发电系统中,必须在时速20英里的风力中处理8倍的能量。
Modern horizontal axis turbines are the most common configuration for wind harvesting. A key feature in virtually all large turbines is the ability to control the pitch of the blades. By controlling blade pitch, the windmill can produce useful electricity over a larger range of wind speeds and can be prevented from exceeding rated shaft speed for high winds (again, because of the V3 effect of increasing wind speed just discussed)。 As a result, of all the wind power opportunities for sensing and system control employing microcontrollers the most basic and critical of these is rotor speed of the variable pitch blades.
