用于微收获设计的电源管理集成电路
微捕集,或从环境中清除环境中的能量,为在各种嵌入式应用中驱动电路提供了新的机会。然而,对于工程师来说,能源供应的高可变性决定了需要满足有效电源管理的要求,以适应这些电路中严格的功率预算和峰值需求,以及管理能量存储设备。有效的解决方案,可以通过一个类从硅制造商包括先进的线性器件,Cymbet,线性的技术、高效的设备发现、集成产品,德克萨斯文书。
能量的来源
微采集对电路设计人员的独特要求。环境能源是变化无常的,最好能提供少量(图1)。工程师们不能想当然地认为电力是可以从这些来源获得的。即使在电源可用时,环境源也不能总是满足低功率应用的峰值功率要求。
Figure 1: Micro-harvesting requires efficient power management because ambient sources can be highly variable power sources, providing miniscule amounts of energy. (Courtesy of Texas Instruments)
One of the implications of the self-powered approach used in micro-harvesting is that power might not be available even to start up a circuit if the energy source has been dormant for too long a period of time. As a result, micro-harvesting designs need to account for “cold-start” capability, where circuits bootstrap the initialization process, powered initially only by the ambient source until sufficient power is available to energize the entire circuit, often by switching on individual sub-circuits in a carefully designed startup sequence.
