光源的显色性
消耗积分:0 | 格式:rar | 大小:0.15 MB | 2017-08-05
分享资料个
  光源的显色性
  美国国家标准与技术研究所(NIST)提出一个颜色质量尺度(CQS),旨在解决目前广泛使用的显色指数对于固态照明的许多缺点。
  这个颜色质量表(CQS)是由(NIST)输入从照明行业和国际照明委员会(CIE)地址的CIE显色指数(CRI)问题的固态光源,以满足照明行业的新需求和消费者沟通的照明产品的颜色质量。计算法的方法是基于用于CRI方法的修正。虽然模拟支持了CQS的适宜性和有效性,视觉实验将进行改进和验证法。然后,它将被提议作为一个新的国际标准。
  Color rendering index vs. color quality scale
  The color appearance of objects under artificial lighting is an important characteristic of light sources, particularly to consumers. Currently, the only internationally-accepted assessment procedure for evaluating the color appearance of objects under light source illumination is the CIE color rendering index (CRI)。
  In the calculation of the CRI, the color appearance of 14 reflective samples is simulated when illuminated by a reference illuminant and the test source. After accounting for chromatic adaptation with a Von Kries correction, the difference in color appearance Ei, for each sample, between the test and reference illumination, is computed in CIE 1964 W*U*V* uniform color space. The special color rendering index (Ri) is calculated for each reflective sample by:
评论(0)
发评论
下载排行榜
