设计传感器AFE热电偶的应用
一个简单的热电偶,结合一个模拟前端,可以提供一个更强大,更低的成本,更广泛的替代其他温度传感器。
1821、Thomas Seebeck发现的物理现象,当两种不同的金属连接的两端,一端加热,连续电流的热电电路产生。¹如果另一端打破,电压是可以测量的,是热结之间的温度差成比例(测量或“热”结)和开放式(参考或“冷”结),测量了。这种特性称为塞贝克效应,是热电偶传感器的基础。
热电偶传感器有几个优点,使之在工业、医疗和家用电器等许多应用领域得到广泛应用。相比其他流行的温度传感器,如温度远程二极管(RTDS)、热敏电阻、热电偶传感器和IC,更坚固,更便宜,并能在最大工作温度范围。此外,热电偶是无源传感器,因此不需要电刺激来操作,从而最大限度地降低系统复杂度。随着他们的许多好处,重要的是要充分理解热电偶的电气特性,当他们设计的时候。
Thermocouple sensors are categorized by different calibration types (e.g., type K and type J) based on types of dissimilar metals which are used to form the thermocouple junction. Based on its calibration type, each thermocouple sensor has a sensitivity (µV/C°), a temperature range, and a non-linear voltage curve over that temperature range. For example, a type K thermocouple has an average sensitivity of approximately 41 µV/°C and an operating range of -200 to 1,250 °C. Thermocouple voltage curves are non-linear over their operating temperature ranges, as can be seen in Figure 1.
