1W音频功率放大器TS4871数据手册
消耗积分:0 | 格式:rar | 大小:1.46 MB | 2017-09-01
分享资料个
  DESCRIPTION The TS4871 is an Audio Power Amplifier capable of delivering 1W of continuous RMS Ouput Power into 8Ω load @ 5V. This Audio Amplifier is exhibiting 0.1% distortion level (THD) from a 5V supply for a Pout = 250mW RMS. An external standby mode control reduces the supply current to less than 10nA. An internal thermal shutdown protection is also provided. The TS4871 has been designed for high quality audio applications such as mobile phones and to minimize the number of external components. The unity-gain stable amplifier can be configured by external gain setting resistors.
  OPERATING FROM VCC = 2.5V to 5.5V ■ 1W RAIL TO RAIL OUTPUT POWER @ Vcc=5V, THD=1%, f=1kHz, with 8Ω Load ■ ULTRA LOW CONSUMPTION IN STANDBY MODE (10nA) ■ 75dB PSRR @ 217Hz from 5V to 2.6V ■ ULTRA LOW POP & CLICK ■ ULTRA LOW DISTORTION (0.1%) ■ UNITY GAIN STABLE ■ AVAILABLE IN SO8, MiniSO8 & DFN8 3x3mm
1W音频功率放大器TS4871数据手册
评论(0)
发评论
下载排行榜
