With the performance miniaturization and digitalization of today‘s electronics, the power management sector is not only the fastest
growing segment of the analog market, but also the most dynamically changing and increasingly complex. At Texas Instruments (TI),
we have been rapidly growing our portfolio of power management devices to be the supplier you look to first for premier power
management products.
Regardless of your design expertise or time constraints, TI can provide you with an ideal power management solution. Whether you
require a plug-in power module to optimize your time-to-market, you need an application note and evaluation module (EVM) to help in
your design, or you require a highly integrated, complex IC with which to design your own power supply, TI has a solution for you.
This selection guide is designed to help you quickly sort through the broad product offering of TI’s premier Power Management
portfolio.A There are 15 sections representing the many different categories of power management products offered by TI.
Each section is designed to provide you with:
• Key topics to consider
• Graphical representation of the portfolio
• Table of the key parameters of the devices
• Available resource information
For more information or technical assistance, please see the back cover, or visit TI‘s web site at power.ti.com
