Each driver consists of a set of functions covering all peripheral features. The development of each
driver is driven by a common API (application programming interface) which standardizes the driver
structure, the functions and the parameter names.The driver source code is developed in „Strict ANSI-C‟ (relaxed ANSI-C for projects and example files)。 It is fully documented and is MISRA-C 2004 compliant. Writing the whole library in „Strict ANSI-C‟ makes it independent from the development tools. Only the start-up files depend on the development tools.Thanks to the Standard Peripheral Library, low-level implementation details are transparent so that
reusing code on a different MCU requires only to reconfigure the compiler. As a result, developers can
easily migrate designs across the STM32 series to quickly bring product line extensions to market
without any redesign. In addition, the library is built around a modular architecture that makes it easy to tailor and run it on the same MCU using hardware platforms different from ST evaluation boards.
The Standard Peripheral Library implements run-time failure detection by checking the input values for
all library functions. Such dynamic checking contributes towards enhancing the robustness of the
software. Run-time detection is suitable for user application development and debugging. It adds an
overhead which can be removed from the final application code to minimize code size and execution
全部1条评论
