AH3761高灵敏度霍尔效应锁存器
消耗积分:0 | 格式:rar | 大小:0.43 MB | 2017-09-22
分享资料个
  The AH3761 is an integrated Hall effect latched sensor designed for electronic commutation of brush-less DC motor applications. The device includes an on-chip Hall voltage generator for magnetic sensing, a comparator that amplifies the Hall voltage, and a schmitt trigger to provide switching hysteresis for noise rejection, and open drain output. An internal bandgap regulator is used to provide temperature compensated supply voltage for internal circuits and allows a wide operating supply range. If a magnetic flux density larger than threshold Bop, DO is turned on (low)。 The output state is held until a magnetic flux density reversal falls below Brp causing DO to be turned off (high)。
AH3761高灵敏度霍尔效应锁存器
评论(0)
发评论
下载排行榜
