With its unique array of configurable blocks, PSoC® 5LP is a true system level solution providing microcontroller unit (MCU), memory,
analog, and digital peripheral functions in a single chip. The CY8C54LP family offers a modern method of signal acquisition, signal
processing, and control with high accuracy, high bandwidth, and high flexibility. Analog capability spans the range from thermocouples
(near DC voltages) to ultrasonic signals. The CY8C54LP family can handle dozens of data acquisition channels and analog inputs on
every general-purpose input/output (GPIO) pin. The CY8C54LP family is also a high-performance configurable digital system with
some part numbers including interfaces such as USB, and inter-integrated circuit (I2C)。 In addition to communication interfaces, the
CY8C54LP family has an easy to configure logic array, flexible routing to all I/O pins, and a high-performance 32-bit ARM®
Cortex™-M3 microprocessor core. You can easily create system-level designs using a rich library of prebuilt components and boolean
primitives using PSoC® Creator™, a hierarchical schematic design entry tool. The CY8C54LP family provides unparalleled
opportunities for analog and digital bill of materials integration while easily accommodating last minute design changes through simple
firmware updates.
