The SKW71 module integrates a 1T1R 802.11n Wi-Fi radio, a MIPS 24K processor, 2-port fast Ethernet PHY, USB2.0 host, I2S and multiple slow IOs. Solution for low power, low-cost, and highly integrated AP router and consumer electronic devices, the module requires only an external 3.3V power supply. It supports 802.11n operating up to 72.2 Mbps for 20 MHz and 150 Mbps for 40 MHz channel respectively, and IEEE 802.11b/g data rates. The module supports AP mode and client mode and repeater mode and UART WiFi. The high performance module can process advanced applications effortlessly, such as routing, security and VoIP.
