Cypress MicroSystems Programmable System on Chip
(PSoC™) microcontroller provides highly flexible I/O with
every pin having configurable drive modes, interrupts and
global routing connections.
Assembly vs. C
Efficient software is vital for embedded system design,
especially with respect to I/O routines. PSoC MCU I/O
ports are highly configurable, and directly accessible by
firmware bit operations in PSoC Designer. This provides
maximum flexibility for programmers. However, it can
require code that is difficult to read
Consider this common example: A hardware engineer
wants to clear bit 6 of I/O port 0 (P0[6])。 With a PSoC
microcontroller, they would write the following assembly
code:
