LC2 MOS微处理器兼容的14位数模转换器AD7538数据表
消耗积分:0 | 格式:rar | 大小:0.32 MB | 2017-10-16
分享资料个
  The AD7538 is a 14-bit monolithic CMOS digital-to-analog converter (DAC) that uses laser trimmed thin-film resistors to achieve excellent linearity. The DAC is loaded by a single 14-bit wide word using standard chip select and memory write logic. Double buffering, which is optional using LDAC, allows simultaneous updates in a system containing multiple AD7538s. A novel low leakage configuration enables the AD7538 to exhibit excellent output leakage current characteristics over the specified temperature range. The AD7538 is manufactured using the linear-compatible CMOS (LC2 MOS) process. It is speed compatible with most microprocessors and accepts TTL or CMOS logic level inputs.
评论(0)
发评论
下载排行榜
