镁光MT29F系列FLASH规格书
消耗积分:0 | 格式:rar | 大小:2.12 MB | 2017-10-17
分享资料个
  Single-level cell (SLC) technology
  • Organization
  – Page size x8: 2,112 bytes (2,048 + 64 bytes
  – Block size: 64 pages (128K + 4K bytes)
  – Plane size: 2,048 blocks
  – Device size: 4Gb: 4,096 blocks; 8Gb: 8,192 blocks;
  16Gb: 16,384 blocks
  • READ performance
  – Random READ: 25µs (MAX)
  – Sequential READ: 25ns (MIN)
  • WRITE performance
  – PROGRAM PAGE: 220µs (TYP)
  – BLOCK ERASE: 1.5ms (TYP)
  • Data retention: 10 years
  • Endurance: 100,000 PROGRAM/ERASE cycles
  • First block (block address 00h) guaranteed to be
  valid up to 1,000 PROGRAM/ERASE cycles1
  • Industry-standard basic NAND Flash command set
  • Advanced command set:
  – PROGRAM PAGE CACHE MOD
  – PAGE READ CACHE MOD
  – One-time programmable (OTP) commands
  – Two-plane commands
  – Interleaved die operations
  – READ UNIQUE ID (contact factory
  – READ ID2 (contact factory)
  • Operation status byte provides a software method of
  detecting:
  – Operation completion
  – Pass/fail condition
  – Write-protect status
  • Ready/busy# (R/B#) signal provides a hardware
  method of detecting operation completion
  • WP# signal: write protect entire device
  • RESET required after power-up
  • INTERNAL DATA MOVE operations supported
  within the plane from which data is read
镁光MT29F系列FLASH规格书
评论(1)
发评论
飞鱼2020 2020-12-21
0 回复 举报
资料 收起回复
下载排行榜
全部1条评论
