z Supply current is brought on
chip at specific locations
» on the edge for most chips
which are peripherally
bonded
» distributed over the area of
the chip for area bonded (C4,
solder ball) chips
z Loads consume this current at
different locations on the chip
at different times
z There is often a large parasitic
inductance associated with
each bond-wire or solder-ball
(0.1-10nH)
z Current is distributed from
the bond pads to the loads
on thin metal wires
» 0.04Ω/ typical
z Load currents may be very
high
» average current may be as
large as 20A for very hot
chips (50W at 2.5V)
» peak current may be 4-5x
this amount (100A!)
z L di/dt of bond wire and IR
drop across on-chip wires
are often a major source of
supply noise
