12伏MOSFET具有输出禁用功能的驱动程序ADP3650数据表
消耗积分:0 | 格式:rar | 大小:0.41 MB | 2017-10-27
分享资料个
  The ADP3650 is a dual, high voltage MOSFET driver optimized for driving two N-channel MOSFETs, the two switches in a nonisolated synchronous buck power converter. Each driver is capable of driving a 3000 pF load with a 45 ns propagation delay and a 25 ns transition time. One of the drivers can be bootstrapped and is designed to handle the high voltage slew rate associated with floating high-side gate drivers. The ADP3650 includes overlapping drive protection to prevent shoot-through current in the external MOSFETs. The OD pin shuts off both the high-side and the low-side MOSFETs to prevent rapid output capacitor discharge during system shutdown. The ADP3650 is specified over the temperature range of −40°C to +85°C and is available in 8-lead SOIC_N and 8-lead LFCSP packages.
评论(0)
发评论
下载排行榜
