FP7208规格书资料
消耗积分:0 | 格式:pdf | 大小:443KB | 2017-11-07
h1654155281.8177
分享资料个
FP7208是一颗异步升压LED驱动IC,控制外部开关NMOS,反馈电压默认为0.104V,最大是0.204V,反馈电压低,取样电阻功率损耗也降低,整体转换效率提升。 软启动时间透过外部电容调整,LED开路保护透过外部电阻调整;调光控制EN Pin,EN内部有滤波器,可以实现线性与数字调光,内置过热保护功能。
  General Description The FP7208 and FP7208B are boost topology switching regulator for LED driver. They provide built-in gate driver pin for driving external N-MOSFET. The non-inverting input of error amplifier connects to a 0.1V default reference voltage. They have programmable soft start time set by external capacitors, and over voltage protection set by external resistors. FP7208B has programmable frequency set by external resistor. The LED current can be adjusted by applying an external signal to the EN pin. The EN pin accepts either a DC voltage or a PWM signal. The PWM signal filter components are contained within the chip. The FP7208B is available in the small footprint DFN-10L package to fit in space-saving PCB layout for application fields. Features : Wide Supply Voltage Operating Range: 2.5V to 24V : Precision Feedback Reference Voltage: 0.1V (±2%) : Analog and Digital Dimming Control : Shutdown Current: 《 6µA : Internal Fixed PWM Frequency: 200KHz / FP7208 : Programmable PWM Frequency: 100KHz~1000KHz / FP7208B : Programmable Soft Start Function (SS) : Programmable Over Voltage Protection (OVP) : Over Temperature Protection (OTP) : Package: SOP-8L(EP) / FP7208, DFN-10L / FP7208B Applications : LED Module : Display Backlight : Car Lighting : Portable LED Lighting
评论(0)
发评论
下载排行榜
