The STM32F40x/41x/427/437/429/439/401/411xE DSP and Standard Peripherals Library is a complete package, consisting of device drivers for all of the standard device peripherals, for STM32F405xx/407xx, STM32F415xx/417xx, STM32F427xx/437xx, STM32F429xx/439xx, STM32F401xx, STM32F411xE andSTM32F446xx devices 32-bit Flash microcontrollers.
This library is a firmware package which contains a collection of routines, data structures and macros covering the features of STM32F40xxx/41xxx/
427xx/437xx/429xx/439xx/401xx/411xE/446xx peripherals. It includes a description of the device drivers plus a set of examples for each peripheral. The firmware library allows any device to be used in the user application without the need for in-depth study of each peripheral’s specifications.
This Library contains also the CMSIS DSP Software Library, which feature a suite of common signal processing functions for use on Cortex-M processor based devices. The library is completely written in C and is fully CMSIS compliant. High performance is achieved through maximum use of Cortex-M4F intrinsics. For more details, please refer to CMSIS DSP Software Library
Using the Standard Peripherals Library has two advantages: it saves significant time that would otherwise be spent in coding, while simultaneously reducing application development and integration costs.
The STM32F40x/41x/427/437/429/439/401/411xE DSP and Standard Peripherals Library is full CMSIS compliant.
