1.The C Programming Language is a powerful, flexible and potentially portable high-level programming language. 2.The C language may be used successfully to create a program for an 8-bit MCU, but to produce the most efficient machine code, the programmer must carefully construct the C Language program. 3.The programmer must not only create an efficient high level design, but also pay attention to the detailed implementation.
