DESCRIPTION The PS8101 is an optically coupled isolator containing a GaAlAs LED on the light emitting diode (input side) and a PIN photodiode and a high-speed amplifier transistor on the output side on one chip. This is a plastic SOP (Small Out-line Package) type for high density applications. FEATURES PIN CONNECTION (Top View) 1. Anode 2. Cathode 3. GND 4. VO 5. VCC 5 3 1 2 4 • High common mode transient immunity (CMH, CML = ±10 kV/μs MIN.) • Small package (5-pin SOP) • High supply voltage (VCC = 35 V) • High isolation voltage (BV = 2 500 Vr.m.s.) • High-speed response (tPHL = 0.8 μs MAX., tPLH = 1.2 μs MAX.) • Ordering number of taping product: PS8101-F3, F4: 2 500 pcs/reel • Pb-Free product • Safety standards • UL approved: File No. E72422 • DIN EN60747-5-2 (VDE0884 Part2) approved: No. 40008902 (Option) APPLICATIONS • Computer and peripheral manufactures • General purpose inverter • Substitutions for relays and pulse transformers • Power supply
