LT1368/LT1369 pdf datasheet
消耗积分:2 | 格式:rar | 大小:666 | 2008-08-06
李丽
分享资料个
The LT1366/LT1368 are available in plastic 8-pin PDIP and
8-lead SO packages with the standard dual op amp pinout.
The LT1367/LT1369 feature the standard quad pinout,
which is available in a plastic 14-lead SO package. These
devices can be used as plug-in replacements for many
standard op amps to improve input/output range and
precision.
n Rail-to-Rail Buffer Amplifiers
n Low Voltage Signal Processing
n Supply Current Sensing at Either Rail
n Driving A/D Converters
评论(0)
发评论
下载排行榜
