汽车控制系统中螺线管电流的测量
消耗积分:3 | 格式:rar | 大小:444 | 2010-01-26
分享资料个
汽车控制系统中螺线管电流的测量
By Scott Beversdorf Chuck Whiting
Solenoids in Automotive Control Applications
A solenoid is a linear motor with a fixed range of travel. Solenoids may be designed for simple on-off applications, acting much like relays. For example, they are used this way in starters and door locks.
On the other hand, a linear, or proportional, solenoid is one whose position can be controlled in a precise manner. They are used to operate pistons and valves for accurate control of fluid pressure or flow in applications such as transmissions and fuel injection.
评论(0)
发评论
下载排行榜
