The TC07 is a programmable, logic output temperature detector that operates from power supply levels as low as 2.7V. Programming is accomplished with external resistors connected from the temperature set point input (TSET) and the hysteresis control input (HSET) to VDD. Complementary outputs (OUT and OUT) are driven active when temperature exceeds the temperature threshold programmed by the resistor on TSET. The states of these outputs are maintained (latched) until temperature falls below threshold programmed by the resistor on HSET. The TC07 has an operating temperature range of -40°C to +125°C (TC07VXA). It features low (<130μA) supply current and with 8-pin MSOP and 8-pin SOIC packages, making it suitable for a wide variety of applications.
