微星 Wind U100上网本英文版说明书
消耗积分:0 | 格式:rar | 大小:3483 | 2010-02-06
SKY_HAWK_1994
分享资料个
微星 Wind U100上网本英文版说明书.zip
This equipment has been tested and found to comply with the limits for a Class B digital device,
pursuant to part 15 of the FCC rules. These limits are designed to provide reasonable protection
against harmful interference in a residential installation. This equipment generates, uses and
radiates radio frequency energy, and, if not installed and used in accordance with the instructions,
may cause harmful interference to radio communications. However, there is no guarantee that
interference will not occur in a particular installation. If this equipment does cause harmful
interference to radio or television reception, which can be determined by turning the equipment off
and on, the user is encouraged to try to correct the interference by one or more of the following
measures:
􀂄 Reorient or relocate the receiving antenna.
􀂄 Increase the separation between the equipment and receiver.
􀂄 Connect the equipment into an outlet on a circuit different from that to which the receiver is
connected.
􀂄 Consult the dealer or an experienced radio TV technician for help.
NOTE
􀂊 The changes or modifications not expressly approved by the party responsible for
compliance could void the user’s authority to operate the equipment.
评论(0)
发评论
下载排行榜
