超微 X6DAL-G主板英文版说明书
消耗积分:0 | 格式:rar | 大小:1023 | 2010-02-09
h1654155805.2668
分享资料个
超微 X6DAL-G主板英文版说明书.zip
Safety Instructions
1. Always read the safety instructions carefully.
2. Keep this User Manual for future reference.
3. Keep this equipment away from humidity.
4. Lay this equipment on a reliable flat surface before setting it up.
5. The openings on the enclosure are for air convection hence protects the equipment from overheating. Do not cover the openings.
6. Make sure the voltage of the power source and adjust properly 110/220V before connecting the equipment to the power inlet.
7. Place the power cord such a way that people can not step on it. Do not place anything over the power cord.
8. Always Unplug the Power Cord before inserting any add-on card or module.
9. All cautions and warnings on the equipment should be noted.
评论(0)
发评论
下载排行榜
