VHDL源代码:
library ieee; --显示器彩条发生器
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity VGA is
port(clk,mode :in std_logic; --扫描时钟/显示模式选择时钟
d,hs,vs,r,g,b:out std_logic); --行,场同步/红,绿,蓝
end VGA;
architecture a of VGA is
signal hs1,vs1,fclk,cclk,divide_clk,dly: std_logic;
signal mmode :std_logic_vector(1 downto 0); --方式选择
signal cnt :std_logic_vector(2 downto 0);
signal fs :std_logic_vector(3 downto 0);
signal cc :std_logic_vector(4 downto 0); --行同步/横彩条生成
signal ll :std_logic_vector(8 downto 0); --长同步/竖彩条生成
signal grbh :std_logic_vector(3 downto 1); --X 横彩条
signal grby :std_logic_vector(3 downto 1); --Y 竖彩条
signal grbx :std_logic_vector(3 downto 1); --文字
signal grbt :std_logic_vector(3 downto 1); --图案
signal grbp :std_logic_vector(3 downto 1);
signal grb :std_logic_vector(3 downto 1);
signal x :integer range 0 to 800;
signal x1: integer range 0 to 800;
signal y1: integer range 0 to 600;
signal x2: integer range 0 to 800;
signal x3: integer range 0 to 800;
signal x4: integer range 0 to 800;
signal x5: integer range 0 to 800;
signal x7: integer range 0 to 800;
signal x8: integer range 0 to 800;
signal x9: integer range 0 to 800;
signal x10: integer range 0 to 800;
signal x11: integer range 0 to 800;
signal y2: integer range 0 to 600;
signal y3: integer range 0 to 600;
signal y4: integer range 0 to 600;
signal y5: integer range 0 to 600;
signal y6: integer range 0 to 600;
signal c: integer range 0 to 30;
