Study on A Control Method of P
消耗积分:5 | 格式:rar | 大小:344 | 2010-02-18
李明
分享资料个
Study on A Control Method of PAPF for Resonance Damping and Harmonics Compensation in Power System:Abstract: In power system, capacitors are widely used to compensate reactive power, which generally cause resonance problems in harmonic distorted network. In this paper, A method of using a PAPF (Parallel Active Power Filter) to damp the resonances is proposed. The proposed method is compound with traditional method, it shows that whether the capacitor current is included in the detecting current of PAPF or not. Also the PAPF with proposed method has strong ability in harmonic compensation. Finally, the experiment results are presented to verify the analysis.
Keyword: Resonance Damping, Power System Harmonics, Capacitors, PAPF (Parallel Active Power Filter).
评论(0)
发评论
下载排行榜
