华硕 P2B主板英文版说明书
消耗积分:0 | 格式:rar | 大小:1739 | 2010-02-23
qsx123456789
分享资料个
华硕 P2B主板英文版说明书
Before installing the memory modules, please comply with the following conditions:
1. Please make sure that the memory used is supported by the motherboard. It is recommended
that memory of similar capacity, specifications and brand be used.
2. Before installing or removing memory modules, please make sure that the computer power
is switched off to prevent hardware damage.
3. Memory modules have a foolproof insertion design. A memory module can be installed in
only one direction. If you are unable to insert the module, please switch the direction.
评论(0)
发评论
下载排行榜
