MAX3660 pdf datasheet (模拟CATV互
消耗积分:3 | 格式:rar | 大小:777 | 2008-08-10
麻酱
分享资料个
The MAX3660 high-linearity analog RF transimpedance
amplifier (TIA) is intended for passive optical network
(PON) video receiver applications. With 66dBΩ maximum
variable gain and integrated uptilt, the MAX3660
provides 23dBmV/channel ±1dB at 870MHz
(19dBmV/channel at 47MHz) for optical inputs between
+2dBm to -8dBm (at 4.2% OMI) using simple feed-forward
automatic gain control (AGC). It can also be configured
with feedback AGC for even greater dynamic
range. CNR is better than 48dB from 47MHz to 870MHz
(1.0A/W photodiode and -165dB/Hz RIN) at -8dBm with
4.2% OMI, or -6dBm with 3.3% OMI. CSO and CTB are
better than -61dBc and -65dBc, respectively. The device
supports extended frequency operation to > 1000MHz.
The very low true-TIA input impedance accommodates
a variety of photodiodes, eliminating the need for an
input matching network and improving yield.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
