Installation
Download from http://www.cadence.com/products/si_pk_bd/downloads/allegroviewers/index.aspx
Opening Files
Allegro opens PCB files with a .brd extension
Simply select File->Open and navigate to the board file that you want to look at
Setting up the view
Always best to start with a clean slate
This example sets up the board for viewing from the top side
Typically, start by zooming to fit the board to the window
Also probably want to turn off the grid dots if they are on
