LPC2114/LPC2124 pdf datasheet
消耗积分:10 | 格式:rar | 大小:667 | 2008-08-24
分享资料个
The LPC2114/2124 are based on a 16/32-bit ARM7TDMI-S CPU with real-time emulation
and embedded trace support, together with 128/256 kB of embedded high-speed flash
memory. A 128-bit wide memory interface and a unique accelerator architecture enable
32-bit code execution at maximum clock rate. For critical code size applications, the
alternative 16-bit Thumb mode reduces code by more than 30 % with minimal
performance penalty.
With their compact 64-pin package, low power consumption, various 32-bit timers,
4-channel 10-bit ADC, PWM channels and 46 fast GPIO lines with up to nine external
interrupt pins these microcontrollers are particularly suitable for industrial control, medical
systems, access control and point-of-sale. With a wide range of serial communications
interfaces, they are also very well suited for communication gateways, protocol converters
and embedded soft modems as well as many other general-purpose applications.
Remark: Throughout the data sheet, the term LPC2114/2124 will apply to devices with
and without the /00 or /01 suffixes. The /00 or the /01 suffix will be used to differentiate
from other devices only when necessary.
评论(1)
发评论
Wu缘Zai见 2015-10-13
0 回复 举报
不错!!! 收起回复
下载排行榜
全部1条评论
