saa7115 pdf datasheet
消耗积分:5 | 格式:rar | 大小:666 | 2008-08-27
张磊
分享资料个
The SAA7115 provides the front-end digitization and
processing of analog video inputs for next-generation
set-top boxes, digital televisions, video projectors,
personal video, and DVD recorders.A single-chip 9-bit
video decoder with 2x-oversampling, the SAA7115
provides video capture for a range of applications
including advanced large-screen devices such as LCD
projectors and HDTVs. Decoding NTSC, PAL and
SECAM signals using fully automatic standard
detection, the SAA7115 also includes a pixel accurate
H/V scaler, a frame accurate audio clock and an
optional square pixel output rate.
Designed with service providers in mind the SAA7115
complies with Macrovision’s Copy Protection Detect
Specification Revision 1.00 and is also well suited for
video surveillance systems requiring ultra-fast frame
switching. In addition, it is fully pin-to-pin compatible
with Philips’ highly successful SAA7114 Video Decoder,
making it the ideal solution for a multitude of
applications.
评论(0)
发评论
下载排行榜
