High-Speed ADC THS1041and FPGA
消耗积分:2 | 格式:rar | 大小:130 | 2010-06-06
建立建利12
分享资料个
ABSTRACT
The Texas Instruments THS1041 is a 10-bit, 40-MSPS, high-speed analog-to-digital
converter (ADC). For many years because of its low power dissipation and extended
life, it has been used in various applications such as programmable gain amplifier and
built-in clamp [1]
. With recent FPGA development, some application systems have been
upgraded with a direct interface of the THS1041 to an FPGA, for example, by
connecting I/O pins of the THS1041 to the I/O pins of Xilinx ™ Spartan-3 or Altera ™
program logic device (PLD). For such an interface, a power-on initial state should be
considered in the interface design. Otherwise, the power-on initial state of the FPGA
can affect the initial state of THS1041 and in some cases, affect the entire application
system. In order to ensure the successful interfacing of the THS1041 to an FPGA, a
test was conducted, and this application report presents those results.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
