TA8435H pdf datasheet
消耗积分:5 | 格式:rar | 大小:666 | 2008-08-28
淡淡的爱
分享资料个
TA8435H PWM CHOPPER TYPE BIPOLAR STEPPING MOTOR DRIVER.
The TA8435H is PWM chopper type sinusoidal micro step bipolar
stepping motor driver.
Sinusoidal micro step operation is accomplished only a clock
signal inputting by means of built−in hard ware.
FEATURES
􀁺 1 chip bipolar sinusoidal micro step stepping motor driver.
􀁺 Output current up to 1.5 A (AVE.) and 2.5 A (PEAK).
􀁺 PWM chopper type.
􀁺 Structured by high voltage Bi−CMOS process technology.
􀁺 Forward and reverse rotation are available.
􀁺 2, 1−2, W1−2, 2W1−2 phase 1 or 2 clock drives are selectable.
􀁺 Package : HZIP25−P
􀁺 Input Pull−up Resistor equipped with RESET Terminal: R =
100 kΩ (Typ.)
􀁺 Output Monitor available with MO IO(MO) = ±2 mA (MAX.)
􀁺 Reset and Enable are available with RESET and ENABLE.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
