TPA5051EVM - User Guide
消耗积分:0 | 格式:rar | 大小:686 | 2010-06-11
cherry1989
分享资料个
The TPA5051 evaluation module (EVM) consists of a single TPA5051 audio delay device, along with other
external components mounted on a printed-circuit board (PCB) that can be used to independently delay
two digital audio streams. Each digital audio stream consists of a left and right channel, both of which can
be delayed up to 4095 samples (with a 48-kHz sampling rate, that equates to more than 85ms of delay).
The TPA5051EVM is designed to work seamlessly with the TI Input USB board, but can function as a
stand-alone board for pass-through testing in any system. All that is required is an I
2 S audio source, an
I
2 C controller, and a 5-V supply.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
