雷达测量基础知识
消耗积分:5 | 格式:rar | 大小:15360 | 2010-06-30
张燕
分享资料个
Table of Contents
Chapter I Introduction    .1
Radar Measurement Tasks Through the life
cycle of a radar system     .1
Challenges of Radar Design & Verification     .1
Challenges of Production Testing    2
Signal Monitoring       2
Basic RF Pulsed Radar Signals      .2
Compressed Pulse signal types and purposes   .3
Linear FM Chirps       3
Frequency Hopping      .3
Phase Modulation       .4
Digital Modulation       4
Radar Pulse Creation      .4
Transmitter Tests       4
Receiver Tests      .4
Chapter II Pulse Generation – Baseband and
RF Modulated Pulses     .5
Overview        .5
Baseband Pulse Generation     .5
Pulse Modulated RF       .6
RF Pulses Directly from an Arbitrary Waveform Generator  .6
Synthesizing Signals Directly in the AWG Series
with RFXpress¤      .7
The Carrier Parameters     .7
Adding Impairments    .7
Adding Interference     .7
Pulse Envelope Parameters      .8
The Staggered PRI Tab     .8
Adding Timing Impairments      .8
Complex Modulations within the Pulse     .9
Graphing the Results    .9
Creating MATLAB® Signals and Importing into the
AWG Series      9
Checking the Phase Modulation     .9
Chapter III Pulse Measurements Methods   .10
Overview       .10
Automated RF Pulse Measurements    12
Short Frame Measurements — The Pulse Model   .12
Sampling the RF       .12
Choosing Measurement Parameters    .12
Measurement Filter Type      13
Detection Threshold and Minimum OFF Time   .13
Maximum Number of Pulses to Measure   14
Frequency Estimation Method    .14
Measurement Point Definitions   .14
Droop Compensation and Rise/Fall Definitions  .15
50% Level Definitions     .15
Finding the Pulse       .15
Minimum Pulse Width for Detection     15
Using the Threshold Setting    16
Finding the Pulse Carrier Amplitude   .17
Method One: Magnitude Histogram    .18
Method Tw Local Statistics    20
Method Three: Moving Average   .20
Noise Histogram (preparation for method four)   .21
Method Four: Least Squares Carrier Fit  .21
Locating the Pulse Cardinal Points    23
Interpolation      .24
Estimating the Carrier Frequency   .24
Constant Phase      .24
Changing Phase     25
Linear Chirp     .25
Making the Timing Measurements   .26
Rise Time/Fall Time    .26
Measurement System Impact on
Rise and Fall times     .26
Pulse Width     .28
Repetition Interval/Duty Cycle    .28
Peak Amplitude      .28
Average ON Power    .28
Average Transmit Power      28
Droop      .29
Pulse Top Ripple     29
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
