CC2400 Errata Notes
消耗积分:2 | 格式:rar | 大小:188 | 2010-07-02
吴藩
分享资料个
When using the CC2400 in buffered mode at data rates below 250 kbps, the last
bit in a packet will not be sent. A software fix solves the problem.
Description and reason for the problem
When the CC2400 is used in buffered mode with an over-the-air data rate lower than
250 kbps, the PA is shut off before the last bit is sent. This will cause problems when
automatic CRC checking is used, as well as if the last byte in a packet contains data.
评论(0)
发评论
下载排行榜
