TRF1600,pdf(True RMS RF Power
消耗积分:5 | 格式:rar | 大小:539 | 2010-07-06
李娜
分享资料个
DESCRIPTION
The TRF1600 is a true RMS power detector with a 28-dB dynamic input range and a linear-to-dB DC output. It is
intended for use in wireless handheld devices such as cell phones and PDAs to measure and control PA output
power accurately independent of the modulation scheme.
The device is designed to operate off of a lithium-ion battery (2.7 V to 5.5 V, 6 V tolerant) or a regulated supply.
A low input signal at the enable pin puts the device in shut-down mode and supply current consumption is
reduced to <5 μA. When asserted high the device enters active mode and outputs a DC voltage proportional to
the RMS value of the input power expressed in dBm.
评论(0)
发评论
下载排行榜
