MAX16804,pdf (High-Voltage, 35
消耗积分:5 | 格式:rar | 大小:344 | 2010-07-20
33391
分享资料个
The MAX16804 current regulator operates from a 5.5V to
40V input voltage range and delivers 35mA to 350mA to
one or more strings of high-brightness LEDs (HB LEDs).
The output current of the MAX16804 is set by using an
external current-sense resistor in series with the LEDs. A
dual-mode DIM pin and on-board 200Hz ramp generator
allow PWM dimming with an analog or PWM input signal.
The analog control signal at dimming input DIM allows for
a theater-dimming effect to be implemented. Fast turn-on
and turn-off times ensure a wide-range PWM operation,
while wave-shaping circuitry minimizes EMI. The differential
current-sense input increases LED current accuracy
and noise immunity. The MAX16804 is well suited for
applications requiring high-voltage input and is able to
withstand automotive load-dump events up to 45V. An
on-board pass element minimizes external components
while providing 3% output-current accuracy. Additional
features include a 5V regulated output and short-circuit and thermal protection.
评论(0)
发评论
下载排行榜
