开源硬件-TIDA-01608-具有集成式分流电阻器和 I2C 接口的隔离式电流检测 PCB layout 设计
消耗积分:10 | 格式:pdf | 大小:526.07KB | 2019-11-28
385288
分享资料个
This verified design can accurately measure current on a bus that carries hundreds of volts. This design is targeted for solar and server applications due to their wide high-voltage input range requirements. This design uses the INA260 current shunt monitor with integrated shunt resistor for (...)
评论(0)
发评论
下载排行榜
