This file contains a summary of what you will find in each of the files that
make up your Md5 DLL.
Md5.dsp
This file (the project file) contains information at the project level and
is used to build a single project or subproject. Other users can share the
project (.dsp) file, but they should export the makefiles locally.
Md5.h
This is the main header file for the DLL. It declares the
CMd5App class.
Md5.cpp
This is the main DLL source file. It contains the class CMd5App.
Md5.rc
This is a listing of all of the Microsoft Windows resources that the
program uses. It includes the icons, bitmaps, and cursors that are stored
in the RES subdirectory. This file can be directly edited in Microsoft
Visual C++.
Md5.clw
This file contains information used by ClassWizard to edit existing
classes or add new classes. ClassWizard also uses this file to store
information needed to create and edit message maps and dialog data
maps and to create prototype member functions.
res\Md5.rc2
This file contains resources that are not edited by Microsoft
Visual C++. You should place all resources not editable by
the resource editor in this file.
Md5.def
This file contains information about the DLL that must be
provided to run with Microsoft Windows. It defines parameters
such as the name and description of the DLL. It also exports
functions from the DLL.
